Question about using wire headers & connectors on both ends
  • This may have been a silly question but in case it helps any other newbies like myself, I did end up adding wire headers and connectors on both ends and it worked out really well. Everything still fits in the case and it also provides the flexibility to connect and disconnect the boards as needed.
  • Connectors on both ends makes a more reliable installation than soldering if you move the cables a lot.
