Hello,
I've finished my Nava 1.02 build few weeks ago. Here are my remaining problems :
- RIM & Snare are not working : no sound from master or individual out. For the snare, when i push the master volume to max, i can hear a really low level hit when trigged by the sequencer.
- HC clap has an infinite decay (last for ever)
Do you guys have some hints to share to start debugging ?
Many thanks!
Fresh 1.02 build // no SN, no RIM, HC with infinite decay
bump!
hey there,
did you ever work out the solution to the infinite hand clap decay issue?
i have the same problem and have reflowed the HC section, as well as check for shorts.
any tips would be greatly appreciated!
The issue with the HC it's probably a broken an6912. The one I got with the kit was broken, and I had the same problem: infinite decay. I replaced It and the clap was perfect. A lot of people experienced this problem.
hey donzo93,
thanks for the reply. Vincent is sending me a replacement AN6912
looking forward to hearing the sweet sweet clap
