Mux/sh problem 1.024 [SOLVED]
I have issues even just having the nava in slave mode for midi sync... hi hats triggering when they shouldn't, weird volume differences.... Not sure about these MUX boards guys.
Not sure if this is related either, but is anyone elses TRIG-1 not working as well?
Mine will only work once I’ve put the sequencer into TAP mode.Teef wrote:Not sure if this is related either, but is anyone elses TRIG-1 not working as well?
Installed 1.025 firmware and everything is working great now!secrethero303 wrote:Yes, this is running firmware 1.024 with the MUX boards on the 1.02 PCBs.druu wrote:Are you running firmware 1.024 with the MUX pcbs?secrethero303 wrote:I have the same issue with external MIDI triggering on my 1.02 board. The internal sequencer works fine, but an external MIDI sequencer only seems to trigger Toms, Clap and very quiet Hi Hats.
Could you confirm that with last v1.025 update it solves your MIDI play issue
Yes, that completely solved the MIDI play issue. It is working great now.e-licktronic wrote:Could you confirm that with last v1.025 update it solves your MIDI play issue
