- Posts 373
Hi folks,
I have a problem with my SD. The VCO decay time is too long as you can hear in this audio example:
https://vocaroo.com/i/s0PIgOB4e5yx
I already checked all envelope caps and resistors, but couldn't find anything wrong here. Any ideas where else I should look? Vincent? Never experienced this with one of my Nava's up to now...
This is how it should sound:
https://vocaroo.com/i/s0KdGLUPVfyZ
KlangGenerator on Nov 15th, '17, 04:39, edited 3 times in total.
- Posts 519
Hi there,
Could you probe ENV1, ENV2, ENV3 and IC36 between pin7 and 14?
It seems that ENV1 does not pitch bend the VCOs correctly.
- Posts 25
(HI KlangGenerator... making my thoughts public - instead of PM)
My guess is, your problem is in any of the two OSC AmpEnvs - ENV2 / ENV3. They both should have a Decay time of about 100ms - but one of yours is way to long! So after 100ms you should hear just the Noise portion.
I've attached some snapshots of the ENV's...
also scope ENV2/3 at C79/C70 - those are the 'real' Envelopes - also pay attention to the curve below 0,5V thats where the coresponding AMP-Transistors Q50/Q51 should close (BE forward Bias?)
ENV1-Pitch
ENV2
ENV2 - C79
ENV3
ENV3 - C70
- Posts 25
btw. I would be very much interessed in following scoped curves - if you (or someone else) can get them:
- BD-NoiseDecay / at C12
- BD-PitchDecay / at IC12A Output
- SD-PitchAmount / at IC35A non-inv-Input
I'm currently preparing the enclosure design for my Expansion-Kit that shalls display original 909 values of the mods.
- Posts 373
Ok, here are a few curves...
SD env1
SD env2
SD env3
SD env4
- Posts 373
Finished a second v1.02 Nava a couple of days ago. Again all instruments fine except too long snare vco decay. Tried and checked out everything, no chance.
- Posts 519
It seems that ENV3 is too long.
You can replace C83 value by 82nF or 68nF.
Try it and let me know
- Posts 373
e-licktronic wrote:It seems that ENV3 is too long.
Thanks Vincent. I tried this, even with 56nf no change. And to be honest, I would prefer to find the reason for this bug without changing the original values. It's really strange that I am having the same problem with two Navas. All components definately have correct values, I checked a thousand times, replaced all transistors, ICs. Even checked all(!) traces with the help of the original schematics. I can't find the reason. I'm very interested to know if other builders experience the same with the new version...
- Posts 47
My snare also has more of a tom sound with the snappy/noise turned down. KlangGenerator did you ever find a fix for this?
- Posts 373
I knew that this must be a v1.02 bug. I have spent countless hours on my two Nava's so far, but up to now I am not able to find the reason for this. Still working on it. If I find something I'll let you know...
