I found the broken trace on IC Pin5 to the via. Haven't tested yet...
Continuity between IC112 pin1 and R447 and D196,197 junction is
GOOD.
What else could be the hihat decay problem?
Distorted? I didn't notice that. I have no spare M5218L Mitsubishi's...
No solder bridges/continuity between the RA9x's (Except the trace where they are all connected). All the RA9x's are connected/continuity to where they are supposed to on IC68.
EDIT>>>
Selecting Open HiHat (Which I didn't do yesterday). VR23 (Open HiHat Decay) does NOT work.
Tried swapping out IC68. No change.
So in summary. Open and Closed HiHat decay does't work.
