Odd power voltages on IC12 in BD section?
  • Also I noticed that one of my b104 pots is measuring 89.1K. Others are measuring 95-96K.
    Is the 89K pot ok? Or should I seek a replacement since it's not actually 100K?
  • None of those pots will be 100% perfect.
  • hofmann25 wrote:None of those pots will be 100% perfect.
    Righto. I wasn't sure if a pot that was off by 10% of its intended value was a no-no. This should function just as well as a true 100K?
    Still concerned about the voltages on IC12 though..
  • Are any voltages on any pins other than power voltage pins a concern as asked in my first post?
    I have now finished the Ride/crash section and am measuring correct power voltages, but on some pins, like the second pin down from top right on IC61, I'm getting a fluctuating voltage from +2.29 to +2.3V.
    I'm very new to all of this and I don't know if this is unusual and a bad indication.
    Would appreciate any help/input.
  • backdoorranky wrote:I'm measuring -14.96 V on pin 4 of all IC points in BD section, and +14.77 on all IC points on pin 8, so I think I'm good there.
    However on IC12 i'm getting..
    Pin 1 - +1.326V
    Pin 2 - +2.51V
    Pin 3 - 0V
    Pin 4 - -14.96V
    Pin 5 - +0.52V
    Pin 6 +1.314V
    Pin 7 - +1.302V
    Pin 8 - +14.79V
    Is this normal behavior?
    This post looks to be a bit old but I'm also measuring similar voltages on my IC12. Does anyone know if this is expected?
    IC12 Voltages
    Pin 1 = +1.338V
    Pin 2 = +2.547V
    Pin3 = 0V
    Pin4 = -15.19V
    Pin5 = +0.523V
    Pin6 = +1.326V
    Pin7 = +1.315V
    Pin8 = +15.08V
  • Probably
