Hihats problems . Bug? [SOLVED]
  • Thanks for sharing! Guess you mean resistor, not capacitor. Would you mind to upload a foto of your mod?
  • I'll try to see if i can duplicate the problem you are describing tonight.
    Do you mean a 47p %10 cap between thoose legs should solve the problems ?
  • Aarrgghh wrote:I'll try to see if i can duplicate the problem you are describing tonight.
    The capacitor value must be 470n - 0.47 micro. Material Polyester
    IC 4011. Pin 1 & 7.
  • eleclove wrote:
    KlangGenerator wrote:Thanks for sharing! Guess you mean resistor, not capacitor. Would you mind to upload a foto of your mod?
    IC 4011. Pin 1 & 7.
    Ok, I'll try out later as I am also experiencing this behaviour of the hats. Didn't notice it though before you pointed it out... ;)
    IC 4011. Pin 1 & 7.
    Works like a charm! Thank you! ;)
    [resize=800]http://www.bilder-upload.eu/upload/3898 ... 621386.jpg[/resize]
  • also did it, and working fine, thx for sharing 8-)
  • Same here! Thank you! :mrgreen:
  • :mrgreen: :mrgreen:
    decoder303 wrote:also did it, and working fine, thx for sharing 8-)
  • So will this cap work fine for the fix? 20% tolerance should be fine, right?
    http://www.mouser.com/search/ProductDet ... 34701C00MS
