Flimsy data encoder?
Posted: Aug 23rd, '16, 08:00
by drifter7508
My data encoder is very flimsy, jumping up and down in value when turned making it hard to get exact BPM. Not a "precision tool". Also under the Shuffle settings it flips up and down when turned.
Is it just mine?
Re: Flimsy data encoder?
Posted: Aug 23rd, '16, 08:54
by Check Mate
No mine is jumping too. I have a hard time to dial in the total accent. Sometimes it just goes up but not down anymore.
Posted: Aug 23rd, '16, 17:47
by ElSchtroumpf
Any suggestions for a better option?
Posted: Aug 23rd, '16, 19:11
by drifter7508
I heard this is probably because of a "software solution only" debouncing it...making it flimsy.
Posted: Aug 24th, '16, 08:08
by beeb
Same with my encoder, it's not that bad but definitely goes the wrong way on some occasions
Posted: Aug 26th, '16, 16:24
by Kazper
Often people use a pair of small film or ceramic caps Between the encoder terminals to filter the true pulses and disregard any noise. Values under 1nF are prefered.
Here is a link to it on a synth.
http://synth.stromeko.net/DIY.html
Posted: Aug 26th, '16, 17:41
by drifter7508
Clever!
Somebody should give it a try on the Nava.
Posted: Sep 16th, '17, 16:57
by jeroenbvo
And somebody did!
I had the same issues but now, no more jumping back and forth!
Actually Bourns are mentioning this in their technical documents:
http://www.bourns.com/docs/technical-do ... f?sfvrsn=4
As I had a bunch of 1000pF left over, I soldered 2 of them "Manhattan style" to the encoder pins. Common ground.
I did not add the two 10K resistors as per above. Anyway R692 and R693 are already part of the circuit as well. It works perfect without the other two.
