My data encoder is very flimsy, jumping up and down in value when turned making it hard to get exact BPM. Not a "precision tool". Also under the Shuffle settings it flips up and down when turned.
Is it just mine?
				Flimsy data encoder?
No mine is jumping too. I have a hard time to dial in the total accent. Sometimes it just goes up but not down anymore.
				Any suggestions for a better option?
				I heard this is probably because of a "software solution only" debouncing it...making it flimsy.
				Same with my encoder, it's not that bad but definitely goes the wrong way on some occasions
				Often people use a pair of small film or ceramic caps Between the encoder terminals to filter the true pulses and disregard any noise. Values under 1nF are prefered.
Here is a link to it on a synth.
http://synth.stromeko.net/DIY.html
Clever!  Somebody should give it a try on the Nava.
 Somebody should give it a try on the Nava.And somebody did!
I had the same issues but now, no more jumping back and forth!
Actually Bourns are mentioning this in their technical documents: http://www.bourns.com/docs/technical-do ... f?sfvrsn=4
As I had a bunch of 1000pF left over, I soldered 2 of them "Manhattan style" to the encoder pins. Common ground.
I did not add the two 10K resistors as per above. Anyway R692 and R693 are already part of the circuit as well. It works perfect without the other two.
