Is still someting going on here? Any dev-activity?
Re: Is still someting going on here? Any dev-activity?
Postby antto » Nov 8th, '16, 17:30
don't worry, we certainly don't expect everything to be said in one post
we expect a discussion which would clear the fog and bring out the important stuff
one way to get started with the plan is:
imagine the yocto, without any labels on the panel
now, imagine you're in the mood to make a bangin' beat/track together with some other gear
so you switch on the yocto - and what do you do?
i hope i explained it well enough
answering this, or just picking up this imaginary story and continueing it forward may give some answers about what features the sequencer should have and why
PS: a small clarification about individual accents: from the sequencer interface - surely it's possible, even multiple levels or a software accent knob, but this can only go out as MIDI
the 808/yocto cannot have individual accents due to the design of the circuit (that is, without modification)
antto
Postby FlavioB » Nov 8th, '16, 21:04
Hi antto - thanks for your feedback, which also keeps this thread alive.
Your suggestions is interesting, never thought about it... in fact, I might be a lazy guy and thus I rather work with what each specific piece of gear allows me to do (working somehow with its "restrictions" - whenever possibile and as long as it suits me)... I'd be happy to read from other ppl in this thread, what they think the Yocto OS should look like...
For the time being, I would really base myself on QS-606 manual - that pretty nails it from my point of view.
Of course, pattern rotation and maybe polyrhythmicity would be great as well.
With regards to the "individual accent", I remember having read the same thing: it needs some hardware modification to achieve this. If it'd be a not-so-invasive modification, which could be placed inside the Yocto 1.0 enclosure, then I could think of having it installed by my personal tech guy... ;)
So - ppl: let's drop ideas into this thread!!!
BR,
Flavio.
FlavioB
Postby richardlawson1489 » Dec 30th, '16, 07:38
Hi pistrix! Thanks for working on this. We have all my hopes with you. Good Luck.
richardlawson1489
Postby antto » Jan 27th, '19, 13:48
so i had some little time to modify my yocto so that it's safer to have it opened while powered up (removed the 230VAC from it)
since i don't like the slowness of MIDI SYSEX for bootloaders, i was planning to use an AVR programmer attached to the programmer port, with its cable coming out of the case thru some hole or gap
but after i was looking at the schematic for some other things i noticed something that looks like a nasty little flaw
the first 74xx165 shift register (IC2) has its data pin directly connected to the atmega SPI_MISO (and thus also to the programmer port)
this data pin is not tri-stated, so as long as the chip is powered - it will drive that pin, and thus if i connect a programmer - something will heat up and probably fry
this really sux
i could make an adapter PCB which plugs into the atmega socket and has a (maybe different) cpu wired differently, and with on-board SPI FRAM memory and stuff.. but this makes things complicated
the requirement for a cpu modification is like a wall, many users can't or don't want to jump over it
and while the situations is similar with the x0xb0x, the x0xb0x at least had the hardware potential for really great features (since it has a decent amount of LEDs and buttons)
the same isn't true for the yocto
blah.. no sure what to do now.. :cry:
antto
Postby helectromagneticus » Feb 16th, '19, 19:04
antto wrote:so i had some little time to modify my yocto so that it's safer to have it opened while powered up (removed the 230VAC from it)
this really sux
In practice, this issue with the SPI MISO plugged directly into IC2's Q pin isn't a problem. I have used an AVR programmer to program the Yocto as described here viewtopic.php?f=17&t=436 quite regularly without incident.
helectromagneticus
Previous
Return to Yocto v1.0 Software
