Page 2 of 4
Re: Yoctov1.0 Firmware Update.
Posted: May 24th, '15, 06:38
by effegee
I can confirm what dac said about SysEx Librarian on Mac and running it at 25% speed. I tried a few times with my go-to app, Elektron's C6, but it was just too fast for the YOCTO to keep up, even though the step LEDs lit up in sequence like they should. Now with the updated firmware I'm sooo happy that the "rolled" RS and CB trigger like they should. It sounds so much better. Merci, Vincent!
Posted: Jun 8th, '15, 09:43
by himijendrix
Thanks for the update! Now the trigger outputs are working very well with my music-from-outer-space synthesizers.
Posted: Sep 13th, '15, 09:06
by punkdisco
Morning all
Just did the 1.0c update and all appears to be good. In particular, the "Midi Slave mode cowbell sounding different" issue is now fixed.
Big thanks.
Paul
Posted: Sep 21st, '15, 11:18
by BastienL
Hi
I did the last update and the roll option doesn't seems to work in midi sync mode, it works in sync out mode though. Anyone as encountered the same issue?
Posted: Sep 30th, '15, 20:32
by punkdisco
BastienL wrote:Hi
Ha, I just logged in to post about this!!
So yes, I have also noticed that Roll does not work when the Yocto is MIDI clock slave.
Hopefully an easy fix?
ta,
Paul
Posted: Oct 8th, '15, 13:35
by Kevdino
I can confirm the previous posts. Having updated my Yocto (I used a USAMO and Sysex Lib on OSX, worked fine after slowing down the speed to 25%), I've now lost the ability to use the roll function in Midi sync mode.
Sidenote: I've tried using the "solo" function and I can't seem to figure out how to "unsolo" a sound after soloing it? The only way to get all the sounds back is to press each instruments' corresponding step and turn them back on. I figured I could press and hold an instrument to solo it and then simply release it to return to the original (unsoloed) pattern. Maybe I'm doing something wrong?
Posted: Oct 11th, '15, 16:45
Kevdino wrote:Sidenote: I've tried using the "solo" function and I can't seem to figure out how to "unsolo" a sound after soloing it? The only way to get all the sounds back is to press each instruments' corresponding step and turn them back on. I figured I could press and hold an instrument to solo it and then simply release it to return to the original (unsoloed) pattern. Maybe I'm doing something wrong?
Dear Kevdino,
Simply push the encoder to unmute all instruments.
Posted: Nov 1st, '15, 10:57
by FlavioB
Hi everybody.
I can confirm that v 1.0c is solving the volume issue when MIDI synced.
Posted: Nov 1st, '15, 10:59
by FlavioB
dac wrote:
On an unrelated note, is there an easy way to dim the LEDs on the Yocto? Is there a resistor change or are they being controlled in software? The LEDs feel like they are burning holes in my eyes at the current brightness!
Hi dac - I'm "suffering" the same issue (burnt eyes
Anything we can do for this? Or has this been posted in some other thread?
Thanks,
F
Posted: Nov 2nd, '15, 15:01
by bmaximus
I've the same issue with the sequencer LED and i think that replace the related resistors with upper value is the only choice. I suggest to prove with a trimmer to seek the right value. Only a thing... I'm not sure at all that the MIDI activity (blinking LED) is visible after the mod...
