hi am I to believe the kit used to come with a preprogrammed ATMEGA which I'm guessing is some sort Of CPU
But now it comes from mouser and is blank :-/ ?
So I buy a ARDNUINO u3 board and hook it up to the yocto and flash the ATMEGA with yocto 2.0
So is that all I need to do? ..... or do I still need to load sysex ( which I'm guessing is yocto_2_0.hex ) after that
And what are the library files for ?
Is that correct ?
Cheers Ciaran
Can someone please explain the ATMEGA situation to me
Dear Ciaran,
First check your Atmega code if it is a atmega1284-PU or atmega1284P-PU.
Then you need to burn the bootloader like describe in this topic viewtopic.php?f=17&t=436.
If you've got an Atmga1284-PU you need to modify the avrdude.conf file like that: Find the avrdude.conf file (<Arduino Dir>\hardware\tools\avr\etc\avrdude.conf)
Search for Atmega1284P and change line : "signature = 0x1e 0x97 0x05" to "signature = 0x1e 0x97 0x06"
Save the file, burn your atmega1284 then changed the signature back to the original 0x05.
If you got an Atmega1284P-PU you can burn the bootloader without modify anything.
Then you have to upload Yocto 2.0 Sysex File via MIDI.
