Pattern reset issue
Pattern reset issue
Postby effegee » Feb 6th, '14, 16:55
I've discovered that when switchig to Pt edit, I sometimes accidentally turn to Track mode, and then when I dial back to Pt edit, the pattern defaults back to Bank 1- Pattern 1. I then have to select the bank and pattern I wanted to edit. This also happens when turning counter-clockwise to "N.C."
Desired behavior: when turning from Track mode (and other modes), resume at most recent pattern played.
effegee
Re: Pattern reset issue
Postby e-licktronic » Feb 17th, '14, 13:54
We will find a solution on the next Update.
Site Admin
Return to Yocto v1.0 Software
