ok guys.. definitely would like to do it right.
i have my brand new arduino UNO, i have a brand new blank ATMEGA 1284P.
installed the Arduino's old 1.0.6 IDE, and i am reading Vincent's guide here
http://www.e-licktronic.com/forum/viewtopic.php?f=17&t=436.
I have downloaded the github folder
https://github.com/HomoElectromagneticus/Yocto_808I unpacked the github folder on the same place as Arduino's.
I followed all the guide steps, at step 7 i also put a 10uF capacitor between reset and ground on the Arduino.
The Bootloader gets burned correctly.
Then i click FILE/SKETCH FOLDER/yocto_808-master/yocto; tools/arduino type/here i tried with either UNO or Yocto 808 16mhz but neither of the two works when i try to upload the file: it tells me
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "YOCTO Boot 16MHz"
Yocto:290: error: 'Serial1' is not a type
Yocto:290: error: 'MIDI' has not been declared
Yocto:290: error: expected constructor, destructor, or type conversion before ';' token
Yocto.ino: In function 'void setup()':
Yocto:318: error: 'Timer1' was not declared in this scope
Yocto:320: error: 'Timer3' was not declared in this scope
Yocto:326: error: 'MIDI' was not declared in this scope
Yocto:326: error: 'MIDI_CHANNEL_OMNI' was not declared in this scope
Yocto:331: error: 'SR' was not declared in this scope
Yocto.ino: In function 'void Chenillard()':
Yocto:356: error: 'SR' was not declared in this scope
Yocto:360: error: 'SR' was not declared in this scope
BPM_fonction.ino: In function 'void Check_BPM()':
BPM_fonction:37: error: 'Timer1' was not declared in this scope
BPM_fonction.ino: In function 'void TestTapeTempo()':
BPM_fonction:128: error: 'Timer1' was not declared in this scope
Check_Edit_Button.ino: In function 'void Check_Edit_Button_Pattern_Edit()':
Check_Edit_Button:24: error: 'SR' was not declared in this scope
Check_Edit_Button.ino: In function 'void Check_Edit_Button_Pattern()':
Check_Edit_Button:169: error: 'SR' was not declared in this scope
Check_Edit_Button.ino: In function 'void Check_Edit_Button_Setup()':
Check_Edit_Button:260: error: 'SR' was not declared in this scope
Check_Edit_Button.ino: In function 'void Check_Edit_Button_Song()':
Check_Edit_Button:337: error: 'SR' was not declared in this scope
EEprom_Fonction.ino: In function 'void Initialize_EEprom()':
EEprom_Fonction:605: error: 'SR' was not declared in this scope
EEprom_Fonction:609: error: 'SR' was not declared in this scope
EEprom_Fonction.ino: In function 'void Dump_EEprom()':
EEprom_Fonction:687: error: 'SR' was not declared in this scope
EEprom_Fonction:712: error: 'midi' has not been declared
EEprom_Fonction:718: error: 'MIDI' was not declared in this scope
EEprom_Fonction.ino: In function 'void Receive_EEprom(const byte*, unsigned int)':
EEprom_Fonction:758: error: 'midi' has not been declared
EEprom_Fonction:769: error: 'SR' was not declared in this scope
EEprom_Fonction.ino: In function 'void Play_Version()':
EEprom_Fonction:874: error: 'SR' was not declared in this scope
EEprom_Fonction:888: error: 'SR' was not declared in this scope
Interruption_fonction.ino: In function 'void Count_96PPQN()':
Interruption_fonction:16: error: 'SR' was not declared in this scope
Interruption_fonction:21: error: 'SR' was not declared in this scope
Interruption_fonction:70: error: 'SR' was not declared in this scope
Interruption_fonction.ino: In function 'void __vector_7()':
Interruption_fonction:201: error: 'SR' was not declared in this scope
Interruption_fonction:206: error: 'SR' was not declared in this scope
Interruption_fonction:233: error: 'SR' was not declared in this scope
Interruption_fonction:306: error: 'SR' was not declared in this scope
Main_Loop.ino: In function 'void loop()':
Main_Loop:30: error: 'MIDI' was not declared in this scope
Main_Loop:53: error: 'MIDI' was not declared in this scope
Main_Loop:79: error: 'MIDI' was not declared in this scope
Main_Loop:132: error: 'SR' was not declared in this scope
Main_Loop:136: error: 'SR' was not declared in this scope
Main_Loop:165: error: 'SR' was not declared in this scope
Main_Loop:169: error: 'SR' was not declared in this scope
Main_Loop:197: error: 'SR' was not declared in this scope
Main_Loop:201: error: 'SR' was not declared in this scope
Main_Loop:231: error: 'MIDI' was not declared in this scope
Main_Loop:254: error: 'MIDI' was not declared in this scope
Main_Loop:281: error: 'MIDI' was not declared in this scope
Main_Loop:302: error: 'MIDI' was not declared in this scope
Main_Loop:316: error: 'SR' was not declared in this scope
Main_Loop:330: error: 'MIDI' was not declared in this scope
Main_Loop:331: error: 'SR' was not declared in this scope
Main_Loop:351: error: 'SR' was not declared in this scope
Main_Loop:357: error: 'MIDI' was not declared in this scope
Main_Loop:376: error: 'SR' was not declared in this scope
Midi_Play.ino: In function 'void Handle_Clock()':
Midi_Play:131: error: 'SR' was not declared in this scope
Midi_Play:137: error: 'SR' was not declared in this scope
Midi_Play:167: error: 'SR' was not declared in this scope
Midi_Play.ino: In function 'void Check_Midi_Channel()':
Midi_Play:237: error: 'SR' was not declared in this scope
Midi_Play.ino: In function 'void Disconnect_Callback()':
Midi_Play:277: error: 'SR' was not declared in this scope
Midi_Play:278: error: 'MIDI' was not declared in this scope
Midi_Play:278: error: 'midi' has not been declared
Midi_Play:279: error: 'midi' has not been declared
Midi_Play:280: error: 'midi' has not been declared
Midi_Play:281: error: 'midi' has not been declared
Mode_Pattern.ino: In function 'void Mode_Pattern()':
Mode_Pattern:7: error: 'SR' was not declared in this scope
Mode_Song.ino: In function 'void Mode_Song_Edit()':
Mode_Song:7: error: 'SR' was not declared in this scope
Mode_Synchro.ino: In function 'void Mode_Synchro(byte)':
Mode_Synchro:13: error: 'Timer1' was not declared in this scope
Mode_Synchro:14: error: 'Timer3' was not declared in this scope
Utility_Pattern.ino: In function 'void Clear_Pattern()':
Utility_Pattern:13: error: 'SR' was not declared in this scope
Utility_Pattern.ino: In function 'void Copy_Pattern()':
Utility_Pattern:93: error: 'SR' was not declared in this scope
Utility_Pattern.ino: In function 'void Paste_Pattern()':
Utility_Pattern:168: error: 'SR' was not declared in this scope
YELP.....PLEASEEEEE!
