Unoffical Firmware Available
Re: Unoffical Firmware Available
Postby mmoody » Jul 1st, '19, 14:57
any fix to the double trigger on tap write?
mmoody
Postby Stazma » Sep 17th, '19, 09:47
Hey there everyone !
I just tested the new firmware and the Trig roll works perfect. Very fun feature to trigger the sequencers of my Grandmother and Jx-3P, i'm sure i'll find some fun use for it with the modulars as well.
Thanks for your work !
Julien
Stazma
Postby FlavioB » Sep 17th, '19, 15:14
Stazma wrote:Hey there everyone !
Julien
Any video available of you playing with this feature on your JX-3P? :-p
F.
FlavioB
Postby Stazma » Sep 19th, '19, 07:18
I'll try to find time to make one ;-)
Stazma
Postby Stazma » Sep 20th, '19, 13:08
Hey there ! Just made this little thing : https://www.instagram.com/p/B2okw7ZoZUC/
Stazma
Postby FlavioB » Sep 20th, '19, 18:12
Stazma wrote:Hey there ! Just made this little thing : https://www.instagram.com/p/B2okw7ZoZUC/
Nice! Thanks! ;-)
F.
FlavioB
Postby helectromagneticus » Oct 31st, '19, 02:31
Very cool!
helectromagneticus
Postby rv0 » Dec 8th, '19, 16:16
Created 2 new Pull Requests on Github:
1) Fix the Sync modes in Track mode
When I previously rewrote how sync is managed in the "edit" modes of pattern play, I totally ignored Track mode.
Here I fix this.
Also fixes issue when pressing "Next" in track mode would cause desync of clock. If anyone wants to test this change:
https://rv0.be/tmp/yocto_firmware_1_2_Track_Mode.syx
2) Fix sync issues in pattern edit when using midi slave mode
This should also improve the Tap entry and Tap-removal
If anyone wants to test:
https://rv0.be/tmp/yocto_firmware_1_2_F ... n_Edit.syx
Have fun :ugeek:
rv0
Postby FactoryDefault » Dec 9th, '19, 05:57
I just spent an hour playing with my yocto1 running 1.2b.
The roll function is SOOO GOOD! :D
I really want to thank everyone who has contributed so far.
I will try to do my part by testing features and reporting back when I can.
FactoryDefault
Postby FlavioB » Dec 10th, '19, 20:01
rv0 wrote:Created 2 new Pull Requests on Github:
Here I fix this.
Have fun :ugeek:
Thanks for your work!
Do the two files contain both fixes, or each of them is one fix - based on 1.2a?
Will you merge those fixes into 1.2b eventually?
Thanks,
Flavio.
FlavioB
PreviousNext
Return to Yocto v1.0 Software
Users browsing this forum: No registered users and 3 guests
