Unoffical Firmware Available
Postby rv0 » Mar 12th, '20, 17:37
Masuto wrote:Thanks for your reply. Since i am unable to transmit the syx via midi, i wanted to try arduino to see if i could do it from there. I burnt the bootloader, but the yocto is non working. No lights, nothing.
I know it’s boring for you to read theough these newbie issues, but really.. it is abit awkward to understand for me-i burnt the bootloader.. and then? How do i burn the unofficial firmware onto the atmega?! Sorry again but maybe this could be useful also to others who cant seem to be able to update to your custom firmware :)
I'd help you if I could, but I don't know either, I only flashed firmware with Midi before.
Perhaps someone else can help you.
It's weird that 2 people report so far here that updating with Midi does not work for them.. Make me wonder if there's not something else going on (e.g. bad batch of parts)
rv0
Postby Masuto » Mar 13th, '20, 11:48
Everything else (and midi incoming sync) works as expected. My board is one of the early pcbs, it’s been working ever since.. ok nevermind, i just hope someone will find a fix eventually because the new features are well appetizing! If anyone can provide a working, unofficial firmware loaded atmega, id happily pay for it :)
Masuto
Postby FlavioB » Mar 13th, '20, 16:59
I just took a look at the revised manual - thanks for it! It's quite accurate IMO...
FlavioB
Postby Masuto » Mar 14th, '20, 13:40
Ok guys. Still here.
SUCCESS i managed to upload the firmware using WIN7. WIN10 just wont do using the same setup and preferences.
If anyone has got issues uploading through MIDI like i had, please check the video https://youtu.be/3g_ZrjYXHH4
YES!!! Happiness!!!
Masuto
Postby rv0 » Mar 14th, '20, 18:26
Masuto wrote:SUCCESS i managed to upload the firmware using WIN7. WIN10 just wont do using the same setup and preferences.
Thats wonderful news :)
Have fun!
rv0
Postby helectromagneticus » Apr 12th, '20, 02:08
I'm glad Masuto is up and running!
helectromagneticus
Postby rv0 » Apr 16th, '20, 10:54
helectromagneticus wrote:I'm glad Masuto is up and running!
Hey,
Hope everyone is fine..
Hows your knowledge of the Cpu trig mechanics?
After doing huge refactors I got kinda stuck with the firmware and it's been in this broken state for a few months now :(
https://github.com/rv0/Yocto_808/tree/trigpulse_rewrite is where I was at, well, that and a git stash of unknown size that I didn't push yet.
rv0
Postby helectromagneticus » Apr 19th, '20, 22:04
Hey,
Without knowing more about your problem, I can't say much about how to fix your code... Maybe a little description of how the CPU trig works will help for now?
The CPU trig is what triggers all of the voices. Each individual drum voice, including accent, has two inputs: one input from the 'global" CPU trig and one input from the instrument-specific pin on the shift registers. You can think of the signals from the shift registers an enables for the drum voices: If the BD signal from the shift register is high, and the global CPU trig is sent, then the bass drum voice will trigger.
For each sequencer step, the Yocto CPU must set new values on the outputs of the shift register so that when the next CPU trig comes, the correct drum voices sound.
Let me know if there's another way I can help!
helectromagneticus
Postby rv0 » Apr 20th, '20, 18:47
Basically my issue is not knowing exactly when to set the CPU TRIG high and when to pull it back low again, if the length is important..
I think my last approach was setting it low at the beginning of each clock pulse, and setting it high after doing all the processing for that pulse, but I dunno, there were side effects :/
I'm gonna be spending some time on it later this week, preparing my brain for the proper state of mind :geek:
rv0
Previous
Return to Yocto v1.0 Software
Users browsing this forum: No registered users and 4 guests
