Unoffical Firmware Available
  • Hey there everyone !
    I just tested the new firmware and the Trig roll works perfect. Very fun feature to trigger the sequencers of my Grandmother and Jx-3P, i'm sure i'll find some fun use for it with the modulars as well.
    Thanks for your work !
    Julien
  • Stazma wrote:Hey there everyone !
    Julien
    Any video available of you playing with this feature on your JX-3P? :-p
  • I'll try to find time to make one ;-)
  • Hey there ! Just made this little thing : https://www.instagram.com/p/B2okw7ZoZUC/
  • Stazma wrote:Hey there ! Just made this little thing : https://www.instagram.com/p/B2okw7ZoZUC/
    Nice! Thanks! ;-)
    Very cool!
  • Created 2 new Pull Requests on Github:
    1) Fix the Sync modes in Track mode
    When I previously rewrote how sync is managed in the "edit" modes of pattern play, I totally ignored Track mode.
    Here I fix this.
    Also fixes issue when pressing "Next" in track mode would cause desync of clock. If anyone wants to test this change:
    https://rv0.be/tmp/yocto_firmware_1_2_Track_Mode.syx
    2) Fix sync issues in pattern edit when using midi slave mode
    This should also improve the Tap entry and Tap-removal
    If anyone wants to test:
    https://rv0.be/tmp/yocto_firmware_1_2_F ... n_Edit.syx
    Have fun :ugeek:
  • I just spent an hour playing with my yocto1 running 1.2b.
    The roll function is SOOO GOOD! :D
    I really want to thank everyone who has contributed so far.
    I will try to do my part by testing features and reporting back when I can.
  • rv0 wrote:Created 2 new Pull Requests on Github:
    Here I fix this.
    Have fun :ugeek:
    Thanks for your work!
    Do the two files contain both fixes, or each of them is one fix - based on 1.2a?
    Will you merge those fixes into 1.2b eventually?
    Thanks,
    Flavio.
