Useful Building Tips
Re: Useful Building Tips
Postby Kazper » Aug 9th, '16, 02:00
Noise Tip
Version 1.0 PCB
Noise layout is to original specifications and does not cover design change & Improvement #5 from the service manual. (Note: some are covered, this is not)
Changes to the following part, will improve adjustment range to set correct 130 MV RMS voltage.
R129 = short
R311 = 100K
R127 = 10uF/16V Electro Cap (C200)
Add C202 to R130
C202 = 22pf Ceramic
Make sure your DMM specifications for RMS type measurements prior to adjusting. Some of the cheap DMM are not RMS and read peak value.
Schematic change is shown on page 8 of the service manual PDF.
https://en.m.wikipedia.org/wiki/Root_mean_square
Kazper
Postby Kazper » Aug 9th, '16, 03:41
Slide Switch grounding tip
Version 1.0 PCB.
Slide switches are not connected to the 0V/Gnd area of the PCB. Some people notice extra noise from the ungrounded metal from the slide switches.
If you have a powered down PCB, a simple continuity check would tell if you have a issue between the mounting legs and the 0V/Gnd area. You can verify ground to the pot mount area that you want to use to connect your switches..
With the slide switches soldered in, solder a small jumper wire between 1 of the 4 mounting legs to one of the next switches legs. Chain them from right to left, attaching the final mounting leg to the ground position you select.
An alternative method would be run from a single switch mounting leg to the nearest pot mount on the same channel.
Verify that it makes connection, and again shortest wire length posible.
Kazper
Postby richardlawson1489 » Sep 29th, '16, 11:00
This is useful. thanks for sharing.
richardlawson1489
Postby baspirco » Oct 4th, '16, 10:09
In Building guide, Snare Drum part 47K resistor says there's 3 items to be placed, only 2 positions available. R234 needs to be added to that.
baspirco
Postby hofmann25 » Nov 3rd, '16, 09:56
Kazper wrote:Cowbell Tip
Version 1.0 PCB, skip the listed values and stuff the following parts:
R44= 100K
R45= 68K
Skip trying to adjust via scope, use a DMM set to HZ and adjust the following to ground.
TM1= 526-540HZ
TM2= 800HZ
Clap should sound like it should...
What do you mean "adjust the following to ground"
Do you probe R44&45 or the actual Trimmers?
hofmann25
Postby Data Jam » Nov 3rd, '16, 12:36
just like in the build guide, but instead with a scope you use the DMM
Data Jam
Postby hofmann25 » Nov 3rd, '16, 19:11
thanks datajam, my DMM doesnt have a hz setting so I'm fine with a scope. But my question was "Do you probe R44&45 or the actual Trimmers?".
So if you are correct in your answer and its the same as the build guide then you probe + to R44&45 ;)
I did this and trimmed the pots to the fundamental frequ, TM1= 526-540HZ (Probe @ R44) & TM2= 800HZ (Probe @ R45).
hofmann25
Postby baspirco » Nov 5th, '16, 16:50
For Middle-Tom : R290 and R291 are not in the Build Guide R290 should be 47K, R291 should be 470K.
Any reason for them not to be in the build instructions?
EDIT : Nevermind, they are to be found in the High-Tom build.
baspirco
Postby richardlawson1489 » Jan 19th, '17, 11:45
Very useful tips. Thanks for sharing.
richardlawson1489
Postby Masuto » Jul 7th, '17, 02:32
Great tips. I will definitely try them for my last batch v1.0 kit! Thanks
Masuto
Previous
Return to Yocto v1.0 Hardware
