Hat voltage +-18V [SOLVED]
  • Dear bleah,
    Measure C88* and C89* voltage. Check the polarity of this capacitors too.
    Are the other ic's voltages -15v , +15v ?
    Do you already solder U7 ?
    Have a look on the HiHat schematic then test all +B3*, -B3* voltage.
  • Well, I don't quite understand what happened but now U7 voltage is around +/-15V after I build the Master section.
    I have socketed U7 but I tested voltage again without IC in place and voltage is good.
    All other IC voltages have been correct.
    Polarity of C88 & C89 are correct.
    So it seems that I don't have problem anymore.
