Here is the last design of the Yocto case. 5mm MDF woods side with 3mm black acrylic case.
you need to cut out 3mm on each side of the overlay to stick on the front panel
Here is EPS files :
krisbo wrote:Does this design use the same nuts and bolts as the original case which were included with the kit?
