Sound is low and some voice not working
Postby PooLP » May 23rd, '20, 08:00
I have a Yocto that I just finished (with a big break of 3 years :)).
I have some problem with it.
On first power up and start seq immediately, on ~first Step the voices have a good volume, after, all voices volume is decreased
Bassdrum, Snare, Rimshot, claves, and handclap do not work (bassdrum ans snare have very low volume)
If i turn clockwise accent Knob, all voices volume decreased
I'm search, but is to hard to find, i have a doubt on BA6110, but I don't think this is the source of all problems.
Here are the pictures, if you see a few things : https://photos.app.goo.gl/oKS8EBhXQ4mAnXuz7
I can't find anything yet.
if there is someone who knows how to repair this machine and who could do it, PM me ;)
Thanks.
PooLP
Re: Sound is low and some voice not working
Postby PooLP » May 29th, '20, 15:58
nobody for help ?
PooLP
Postby gihaume » May 30th, '20, 09:19
If you have an old kit you may want to swap the IC in the accent section because some that e-lick sent were defekt.
It seems you have a lot of non working voices. For each, inspect firstly for soldering issues (there is a few spots where pads are very close but shouldn't connect..), then ICs/transistors and polarized parts orientations, then parts/values placement.
I can physically help in Switzerland, otherwise it's too complicated.
gihaume
Postby PooLP » Jun 5th, '20, 06:53
Thanks :D . I will test.
I made the noise modification of this site (https://masutopedals.wordpress.com/2016 ... ding-tips/), but the other mods are also to be done or this is just improvements?
There is also this site (https://www.dsl-man.de/display/DSO/Yoct ... ding+tipps) which offers mod / fix, are some of them necessary? (first fix it's ok for me)
PooLP
Postby PooLP » Jun 5th, '20, 10:27
ok, after replaced Accent CI and all re-checking, all voice work, but :
Bassdrum have only "Attack sound" (no bass) and decay knob don't work.
The handclap sound is fully saturated, BA6110 burned ?
PooLP
Postby gihaume » Jun 6th, '20, 13:17
For the clap, just change the trimmer setting maybe ? If your BA6110 was burned, I think it most likely wouldn't output any sound (but I am no expert).
For the bassdrum:
- if you have sockets, try to swap U12 with another similar IC
- check C43 value and orientation
- check R170, R164, R169, R168 (absolute) values
gihaume
Return to Yocto v1.0 Hardware
Users browsing this forum: No registered users and 7 guests
