Spare part for the SNAPPY potentiometer
Postby FLOz » May 20th, '18, 19:59
Hello,
Unfortunately the SNAPPY potentiometer of my snare drum (Potentiometer (B103) / VR9 /10K(B)) is broken (functional but the shaft is loose). Do you know where I can find a spare?
Greetings
FLOz
Re: Spare part for the SNAPPY potentiometer
Postby KlangGenerator » May 20th, '18, 22:00
FLOz wrote:Hello,
Greetings
https://www.mouser.de/ProductDetail/Bourns/PTV09A-4030F-B103?qs=Zq5ylnUbLm4pfFuWlwC80Q==
Be aware that the D-shaft doesn't go all the way down to the body and needs to be filed. Otherwise it's an identical replacement.
KlangGenerator
Postby FLOz » May 21st, '18, 09:50
Thanks for your fast reply.
But it seems that the lead spacing doesn't match between both potentiometers:
- The one on mouser has 5mm between pin 1 and 3 (standard lead spacing of 0.1inch).
- The one on the yocto has about 7,5mm between pin 1 and 3. And I don't find anything matching on the web (mouser, tayda, reichelt...).
FLOz
Postby FLOz » May 21st, '18, 12:38
I think I found the correct one: Bourns PDB12-H4251-103BF
https://www.mouser.de/ProductDetail/Bou ... mV5DwNKA==
FLOz
Return to Yocto v1.0 Hardware
Users browsing this forum: Google [Bot] and 4 guests
