Testing each sounds as I build
Postby cablebasher » Jan 21st, '18, 18:14
Hey guys
Just started building my yocto ver1 that I got in May.
I would like to test each sound as I go to make I’m on the right track.
If I sent a trigger In from my eurorack to the trigger in for each sound (from the schematic) should I hear it ok from the output?
Cheers, in advance.
cablebasher
Re: Testing each sounds as I build
Postby unclewoody » Jan 25th, '18, 16:21
There's a bit of info around here on this. You also have to send 5V to the accent input. You can find which resistor to connect to on the schematic.
I initially tried with my Eurorack, but ultimately ended up using an Arduino since that was easier to make a more exact trigger.
unclewoody
Postby cablebasher » Jan 30th, '18, 08:09
Hey Woody
Thanks for the info.
For those interested the thread with the info on testing sounds as you build is:
viewtopic.php?f=16&t=179
Happy building.
cablebasher
Postby cablebasher » Mar 28th, '18, 20:54
hey guys
so i made it as far as the cowbell and all is good so far
I want to test the cowbell but notice on the schematic that there are 2 trigger points rather than the normal one:
one trig going to R14 and another one going to R19 & 18.
Do i need to send a trig to all 3 resistors to hear a sound?
slightly confused.
I should point out that I have the cymbal built (which i need to hear the cowbell)
Thanks again.
cablebasher
Return to Yocto v1.0 Hardware
