Hand Clap Sound problem
Postby muffy1975 » Jan 2nd, '14, 10:38
what did you do to fix the hand clap from the demo on youtube?
I am building the clap from the schematic by Roland and have the same hand clap sound you have on youtube. It does not sound right. What did you do to fix it?
The soundcloud update files you posted sounds correct however. What changed?????
I have aligned .47uf cap + to ground.
I am using the Ba6110 as you have too!. I think i have the conversion right.
Pin 1 to Pin 4
Pin 2 to Pin 2
Pin 3 to Pin 1
Pin 4 to Pin 3
Pin 5,6,7,8,9 all the same as the original BA662
The sound has no body as though the direct clap sound is missing or the speed of the claps is too fast. There is just a Ksssuuuush sound without any KKKLLLLUUUUAAAPPP.
Thanks for any help.
Michael
Oxford
England
muffy1975
Re: Hand Clap Sound problem
Postby e-licktronic » Jan 2nd, '14, 16:22
Dear Muffy1975,
What is your C140 value. On the original schematic it's 2.7nF but with this value you didn't get the 30ms pulse.
You have to change this value to 27nF.
Try to add a 10k resistor between Q70 emitter and -15v PSU that VCA will open to get clap verb.
I hope it will help you
Site Admin
Postby muffy1975 » Jan 3rd, '14, 11:30
HI,
thanks e, thanks for getting back to me.
i will give this a go!
Kind regards
Michael
muffy1975
Postby muffy1975 » Jan 3rd, '14, 18:36
Hey,
yes i had 2n7 there not 27n. Swapped that out and added the 10k resistor to the emitter of q70. The clap sounds too fast and not deep enough still . I suspect i am not getting all the four pulses. Is there any way of checking this. I have scope!!
The clap sound is too fast with no enough body. Is there aany way of slowing down the pulses as per eric archer's clap raca??
Thanks again
Michael
muffy1975
Postby effegee » Jan 4th, '14, 01:53
Muffy,
PM me. I can help you.
effegee
Postby muffy1975 » Jan 5th, '14, 09:16
HI,
i have pm'd you.
thanks indeed for any help
Michael
muffy1975
Postby effegee » Jan 7th, '14, 04:50
Sorry, Muffy, but it won't let me PM you back (it says I'm too new to the forum??).
PM me your email address, please.
effegee
Postby e-licktronic » Jan 7th, '14, 15:37
Dear Muffy,
Maybe you could share your experience on this topic ?
Site Admin
Postby 4teenth » Jan 20th, '14, 16:16
So to clarify - If I'm following the directions online and the printing on the PCB will this be correct or not?
4teenth
Postby e-licktronic » Jan 21st, '14, 14:27
What are you talking about?
Site Admin
Next
Return to Yocto v1.0 Hardware
Users browsing this forum: No registered users and 3 guests
