Hi to all!
I completed the Cowbell section and I don't know if it's all ok or there is a problem.
Actual behaviour is when I play the sound I hear only a sort of short "bump".
My question is: is it normal because the cowbell needs cymbal and hi hats to be completed before or it can be my mistake during the build process?
Consider that I've already built master/io/sequencer sections, only cymbal and hi hats has to be done.
Cowbell volume works and part is triggered by the sequencer.
All other sections play as expected.
Thank you in advance for your kindness.
Patrizio
Cowbell...problem...or not? [SOLVED]
Hi Patrizio,
Actually the cowbell needs two oscillators that are located in the cymbal circuit, so it should work once you completed it. The "bump" you hear is the cowbell enveloppe i guess, so the circuit seems to work as it should.
Let us know how it goes once you've completed the cymbal.
Thank you for your reply!
Yes, you are right, I completed the cymbal section and the cowbell worked.
Now let's go with the last section...
Thank you for your support & help!
Patrizio
Patrizio
You're welcome, glad to hear it works now.
